FAILOVER FEATURE ON CAT 500 24 PORT SWITCH
Jun 16th, 2008
Hi ,,Pls i need advice on how i can deploy a failover solution on cat 500 switch .I have 2 isp connections terminated on the switch every thing is up and running but i need to know if i can implement an intelligent feature on a cat 500 switch that enables it failover the another link when one of the links is down.using a router is not an option as the company i'm implementing for might not be able to afford
mohamednur.a Thu, 06/23/2011 - 01:43
i have cat 500, which i reseted by pressing the setup bottom, the problem is that when i connect it to my laptop lan port or PCI, it doesnt pull the default gateway. as i dont have the device manager cd
