CatOS port statistics
Answered Question
Jun 16th, 2008
Hello all,
I'm after, if it exists, a CatOS command that replicates the 'show interface' which displays the tx and rx load on a port, be it x/255 or y% (as per the sho int command in IOS).
Bernie
Correct Answer by andrew.burns about 8 years 10 months ago
there's no exact equivalent but "show mac utilization" should give you what you need. Might also be worth reading the command reference to see how it's calculated.
Andrew.
Overall Rating: 5 (1 ratings)
Correct Answer
andrew.burns Mon, 06/16/2008 - 04:45
  • Gold, 750 points or more
Andrew.
