Permanent VPN tunel
Jun 16th, 2008
I would like to create perm tunel between work place and my house. I've got ASA 5510 ver7.2(1) and planing to buy cisco router for home. Which one would you recommend?? Also as I'm beginner in VPN could you recommend me a links with the best way to do it??
Farrukh Haroon Mon, 06/16/2008 - 08:52
  • Red, 2250 points or more
Do you have static IPs on both sides or one?
Farrukh
greg.zajac Tue, 06/17/2008 - 00:13
What about routers. Do I need special router to support perm VPN tunel?? any recommendation??
ryancolson Wed, 06/18/2008 - 08:22
if money is an issue and you dont require a lot of processing power for your router, a 1721 would be a good one to start with. They are relatively cheap and will run up to 12.4 with 128 ram
bberry Thu, 06/26/2008 - 07:52
I have a couple logistic companies that connect back to our corporate office using the small Cisco 871-K9. Looks a lot like the D-link / Linksys routers you get at Best Buy.
Brent
