Problem with "pppoe enable group global"
Jun 16th, 2008
I configured a Cisco 1841 fpr PPPoE via Multilink PPP. I try to set the command
for the FastEthernet0/0 and FastEthernet0/1 interfaces. But this command is not accepted, only "pppoe enable" is possible. Is there a big difference, could that cause a problem when I use "pppoe enable" instead of "pppoe enable group global"?
Here the example config for FastEthernet0/0:
interface FastEthernet0/0
description PPPOE WAN1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe-client dial-pool-number 1
no mop enabled
Pravin Phadte Mon, 06/16/2008 - 04:42
If a PPPoE profile is not specified by using the group option, PPPoE sessions will be established using values from the global PPPoE profile.
PPPoE profiles must be configured using the bba-group pppoe command.
PPPoE on an Ethernet Interface Example
The following example enables PPPoE sessions on Ethernet interface 1/0. PPPoE sessions will be established using the PPPoE parameters in the global PPPoE profile.
interface ethernet1/0
pppoe enable
bba-group pppoe global
virtual-template 1
sessions max limit 8000
sessions per-vc limit 8
sessions per-mac limit 2
Hope this helps.
Pravin
Paolo Bevilacqua Mon, 06/16/2008 - 06:32
Hi, despite what some older guide say, you don;t need any command beside pppoe-enable and pppoe-client for PPPoE under ethernet interface.
Note the ip commands under FA0/0 are unnecessary because the interface is not IP enabled, you should put them under dialer interface instead.
Hope thus helps, please rate post if it does!
