IOS SSL VPN Issues
Answered Question
Jun 16th, 2008
Hi Experts.
I cannot get SSL VPN tunnel mode to work on a Cisco1801 Router. I can get the URL side working fine, but when i try and set-up the Tunnel mode using SDM. I get the following error message when i try to connect.
An error has been found in the VPN server certificate.
Certificate received is signed by an untrusted authority.
I then have the option to install the certificate. This process seems to work but i then get the following error.
The SSL VPN HTTP responce code received form the gateway indicates an error, contact your network administartor.
Am i doing something wrong with regards to the certificate?
Correct Answer by Farrukh Haroon about 8 years 11 months ago
I'm sorry, just got a chance to skim through your configs. It seems you are using a VPN pool which is not directly connected to the router. You either need to use a directly connected pool or create a loopback in the same subnet.
Also post output of
debug webvpn tunnel
debug webvpn auth
debug webvpn svc
Farrukh
Overall Rating: 5 (2 ratings)
Correct Answer
Farrukh Haroon Mon, 06/16/2008 - 09:07
  • Red, 2250 points or more
Also post output of
debug webvpn tunnel
debug webvpn auth
debug webvpn svc
Farrukh
priestphil Tue, 06/17/2008 - 02:38
The Pool was the problem, thanks a lot for you help all working now...
