Unity 4.1(1) upgrade to 5.x
Jaime Valencia Mon, 06/16/2008 - 05:09
  • Cisco Employee,
  • Hall of Fame,
    2011
pretty straight forward i would say, if it's on the same HW then nothing should be lost. if migrating to new HW you can refer to the DIRT information from the unity tools depot online to see what will and what won't be backed up
javalenc
if this helps, please rate
chris.fortner Tue, 06/17/2008 - 09:58
Some quick tips...make sure you run the AD schema update for Unity 5.0. Make sure you update the Unity TSP after install.
These are normal causes of issues!
