IPSec VPN Pix 501 Tunnel drops frequently
Jun 16th, 2008
Hi there,
we've got a Pix 501 which creates a VPN tunnel over the Internet that terminates on a VPN3030 Concentrator. The tunnel drops a couple of times a day usually, sometimes for 20 mins or more. Between the Pix 501 and the concentrator there is a Pix 525 firewall which performs NATing.
Firstly, I'm sure that the relevant protocols must be allowed through the Pix 525 (which does the NATing) or the tunnel wouldn't come up at all would it? For information can anyone let me know exactly what to let through the 525 to the concentrator and vice versa so that I can check?
As far as I'm aware you don't need an access list on the Pix 501 as any IPSec traffic coming from the tunnel endpoint (concentrator) will be allowed in anyway (or is this only if the 'sysopt connection permit-ipsec' command is used on the Pix 501?).
Any advice would be appreciated as this problem has been going on for a long time. The concentrator software is around 2003 in case that makes a difference (though other tunnels from other remote Pix 501s seem to be fine).
Here's the Pix 501 config:
Pix# sh run
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname Pix
domain-name testcorp.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 119 permit ip 10.155.117.128 255.255.255.192 10.0.0.0 255.0.0.0
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.248
ip address inside 10.155.117.189 255.255.255.192
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 119
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication telnet console LOCAL
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
snmp-server host outside x.x.x.x poll
no snmp-server enable traps
floodguard enable
crypto ipsec transform-set strong esp-3des esp-md5-hmac
crypto ipsec transform-set medium esp-des esp-md5-hmac
crypto map MyMap1 10 ipsec-isakmp
crypto map MyMap1 10 match address 119
crypto map MyMap1 10 set peer x.x.x.x
crypto map MyMap1 10 set transform-set strong
crypto map MyMap1 interface outside
isakmp enable outside
isakmp key ******** address x.x.x.x netmask 255.255.255.255
isakmp keepalive 10
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
telnet 10.155.117.128 255.255.255.192 inside
telnet 10.155.117.0 255.255.255.192 inside
telnet timeout 5
ssh x.x.x.x 255.255.255.255 outside
ssh timeout 30
: end
Pix#
JORGE RODRIGUEZ Mon, 06/16/2008 - 09:49
  • Green, 3000 points or more
Take a look at this link specially Enable or Disable ISAKMP Keepalives , see if that helps.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml#Solution4
[edit] did not noticed you already have keepalive configure , have you looked at the logs on either to see any relevant information as to why the tunnel drops, even look at each end internet link utilization, or phycal outside interface for packet drops, again.. on specific time of day when tunnel drops, it is possible high traffic on internet link on specific time causes keep alive misses ..
Rgds
-Jorge
