QoS on a Cat4506 running CatOS
Jun 16th, 2008
I'm struggling to find any QoS guides that would contain any information for a 4506 runnign CatOs, all the config guides only seem to be tailored for IOS.
Does anyone have any experience/documentation for configuring QoS on a 4506 running CatOS?
I'm only after some basic QoS setup for voice, trust cos 3 and 5, etc
thanks
elena
Collin Clark Mon, 06/16/2008 - 06:32
  • Purple, 4500 points or more
Use the QOS CatOS config guides for the 6500s, they're nearly identical.
Hope that helps
E-BRITTON Mon, 06/16/2008 - 09:25
thanks for the reply, i've seen that doc already, unfortunately, all the config links seem to lead to IOS configuration guide :-(
andrew.butterworth Fri, 06/20/2008 - 12:05
  • Gold, 750 points or more
The configuration guides for Catalyst 4x00 CatOS are now in the 'end of life/end of sale' documentation pile...
Here is the latest Cat 4000 software 8.3 & 8.4 guides for QoS.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/8.3and8.4glx/configuration/guide/qos.html
There isn't much.... All interfaces are 2q1t and all you can do is Map CoS values to queues, so only Layer-2 802.1p CoS is supported (no Layer-3 DSCP/IP Precedence support). You can set a default CoS value (i.e. rewrite or add an 802.p priority to all incoming frames) and there is no support for ingress or egress polcies (like there is with the Sup2+ and IOS on the 4500).
Andy
