Problems with incoming calls over BRI
Jun 16th, 2008
I have some problems on a cisco 2811 with 2 bri cards (4 interfaces). Incoming calls from special (perhaps analogous) participants are not able to reach any extension.
They are all dialing the head-number plus an extension, but in logging it seems they are only dialing the head-number.
I have overlap-receiving activated, and T302 is set to 12seconds.
paolo bevilacqua Mon, 06/16/2008 - 05:56
  • Hall of Fame,
    Founding Member
Hi, if you don't receive the extension there is little you can do. Post here the complete setup exchange to check taht again.
paolo bevilacqua Wed, 06/18/2008 - 00:43
  • Hall of Fame,
    Founding Member
Config is not needed for now. You should collect "debug isdn q931" with "term mon" and see if the called extension comes in.
