Access-list question
Jun 16th, 2008
We have a PIX 506 firewall and I need to allow a specific IP address, 141.157.129.77 to access a server inside the LAN on port #1999. I created a public IP address for the server but I am not so sure if the following command is correct.
access-list 101 permit tcp host 141.157.129.77 host “public ip address of our server” eq 1999
Thank you
Overall Rating: 3 (1 ratings)
dgroscost Mon, 06/16/2008 - 06:26
Yes, that's correct.
You will need to apply the ACL to your outside interface -
access-group 101 in interface outside (as example)
Depending on your config, you may need to assign a static NAT to your server.
static (inside,outside) public.ip.address internal.ip.address netmask 255.255.255.255
