PVDM
Jun 16th, 2008
Unable to see voice-port command in 3845 router.
PVDM2-64 modules have been installed and displayed in "sh diag"
NM-1CE1T1-PRI has been configured and the "isdn status" is also up.
Any suggestions..
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 06/16/2008 - 06:24
  • Hall of Fame,
    Founding Member
Hi, you cannot use NM-1CE1T1-PRI for voice, that is a data only card.
You need a VWIC or VWIC2 card for voice PRI on an ISR router.
