Cisco 7206 command
Jun 16th, 2008
  • Silver, 250 points or more
I have seen command to bring any module down in cisco 7206 config # hw-module slot number shutdown
can someone pls tell me whats the command to bring it up.
guruprasadr Mon, 06/16/2008 - 06:49
  • Gold, 750 points or more
HI Ajay, [Pls RATE if HELPS]
The HW-Module are Hot-Swappable. Just plug-out and plug-in the Module and it should be Up again.
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
paolo bevilacqua Mon, 06/16/2008 - 06:50
  • Hall of Fame,
    Founding Member
You cannot bring the full module down with a single command, but you cand shutdown the individual interfaces or controllers on the module.
