ADSchemaSetup.log error
Jun 16th, 2008
I try to install Cisco Unity v4.0(5) with Windows 2003 Active Directory and when I run ADSchemaSetup, the following error appears in the log file:
2008-06-13 20:03:49 Error RegQueryValueEx failed with error 2. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 906
2008-06-13 20:03:49 Error Error reading Schema Update Allowed. The value might not exist. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 907
Do you know if the error is critical or not?
Hernan Moya.
Tommer Catlin Mon, 06/16/2008 - 09:58
You should be running the ADschema update from the Global Catalog server if possible. Insert the disc into the GC and run the ADschema update. (or map a network drive) Check your logs on the desktop of the GC to see if it worked.
Hernan Moya Mon, 06/16/2008 - 10:26
I run it from the GC Server with Schema Admins privilegies and the error messages appears on the log file.
Hernan Moya Mon, 06/16/2008 - 11:18
From the LDIF.LOG file I don't have any errors. But from ADSchemaSetup.log file the result was:
2008-06-13 20:03:34 Information The log path is: C:\Documents and Settings\eaglebkb\Desktop\ldif logs\20080613-200334\ e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetup.cpp 166
2008-06-13 20:03:49 Information Verifying RemoteRegistry Service. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 169
2008-06-13 20:03:49 Information Bind to LDAP://CN=Schema,CN=Configuration,DC=Itauchile,DC=cl. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 643
2008-06-13 20:03:49 Information Get "allowedChildClassesEffective" attribute from SchemaContainer e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 675
2008-06-13 20:03:49 Information Iterate through values and look for classSchema. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 695
2008-06-13 20:03:49 Information Check if user is in Schema Admins security group. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 234
2008-06-13 20:03:49 Information Entering CADSchemaSetupDialog::IsInSchemaAdminsGroup. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 724
2008-06-13 20:03:49 Information Get "objectSid" attribute from RootDomainNamingContext. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 743
2008-06-13 20:03:49 Information Current account SID was not found in Schema Admins group. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 837
2008-06-13 20:03:49 Information Connect to registry at \\CLSTGDCSP03. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 856
2008-06-13 20:03:49 Information Set the safety interlock to 1. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 292
2008-06-13 20:03:49 Information The ldifde command line is: ldifde.exe -i -k -c "" "CN=Schema,CN=Configuration,DC=Itauchile,DC=cl" -s "CLSTGDCSP03" -f "Z:\Schema\LdifScripts\avdirmonex2k.ldf" -j "C:\Documents and Settings\eaglebkb\Desktop\ldif logs\06132008_160349\avdirmonex2k" e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 378
2008-06-13 20:04:10 Information Safety interlock was not initially set. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 490
2008-06-13 20:04:10 Information Delete safety interlock value. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 491
2008-06-13 20:04:10 Information Schema update was successful. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 505
2008-06-13 20:04:17 Information Exiting ADSchemaSetup. e:\Views\cs_CU4.0.4.221\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetup.cpp 175
Is there any restriction to install it on Windows 2003 Actve Directory?
Any idea?
Thanks.
chris.fortner Tue, 06/17/2008 - 09:11
In the log file it checks to see if you SID is listed in the Schema Admins group and fails. Is the AD replication healthy? It would seem that the AD was queried and the reponding server did not have your account SID listed in the schema admins group.
