MPLS route map
Jun 16th, 2008
Is it possible to configure PBR using route maps on the MPLS. We need to do add a different internet route based on extended access-list which will be different from the default route in the MPLS
n.nandrekar Wed, 06/18/2008 - 20:36
  • Silver, 250 points or more
Hi!
I am not sure about other devices but atleast on 6500/7600, PBR for mpls traffic is not supported in hardware. All the packets will be processed by the CPU and will spike the CPU utilization. So it is not recommended to use PBR for the ip-to-tag path.
Niranjan.
(please rate helpful posts)
o.ilesanmi Thu, 06/19/2008 - 00:19
Thanks for the response.
So how do i achieve this?
madedotun Fri, 06/20/2008 - 04:42
With regards to the following, how do you implement route policy on MPLS
