How to get serial number with command (show diag not working)
Answered Question
Jun 16th, 2008
Folks, I need to get serial number from remote 6509.
I tried 'show diag' but no output returned.
This is IOS version 12.2(18).
Correct Answer by foxbatreco about 8 years 11 months ago
Sh ver command should work with 6509 to view the serial no.
U can find it appended with Process Board ID.
Pls rate/mark if this helps!!!
Correct Answer by otzispadmin about 8 years 11 months ago
Does sh ver work? The processor board id is the s/n.
Correct Answer by Collin Clark about 8 years 11 months ago
Try show inventory
Hope that helps
Overall Rating: 5 (3 ratings)
Correct Answer
Collin Clark Mon, 06/16/2008 - 09:12
  • Purple, 4500 points or more
Try show inventory
Hope that helps
Correct Answer
otzispadmin Mon, 06/16/2008 - 09:13
Correct Answer
foxbatreco Mon, 06/16/2008 - 10:24
  • Bronze, 100 points or more
news2010a Mon, 06/16/2008 - 10:41
True. I did not realize that "processor board" is the same than "SN"!
Thanks all!!!
hsitar007 Tue, 06/17/2008 - 05:46
'Show module' would be the appropriate command on a 6509. It would even provide the card serial number along with the chassis serial number.
Ratish
h.parsons Tue, 06/17/2008 - 11:55
I use "show idprom backplane" if you are looking for the chassis SN. If not the there are other options after "show idprom ________"
