06-16-2008 11:06 AM - edited 03-10-2019 03:54 PM
Hello.
I have a Cisco 2610XM with firmware version c2600-ipvoicek9-mz.124-15.T5.bin. Could someone tell me how to suppress the ALIVE accounting packets coming to my Radius server?.
I have been trying using the command "no aaa accounting update" but it keeps sending the ALIVE accounting packets.
Thank in advance,
Ricardo.-
06-16-2008 08:19 PM
I'm not sure whether you are using RADIUS Server Load Balancing or not, but the following document does discuss commands used for "RADIUS Server Status and Automated Testing", and may provide you with the configuration guidance you need:
http://www.cisco.com/en/US/docs/ios/12_2sb/feature/guide/sbrdldbl.pdf
... hopefully.
06-17-2008 02:24 AM
Did you try the solution posted in the MARS forum?
Farrukh
06-17-2008 11:54 AM
Hi Farrukh.
I tested the "no gw-accounting aaa" but it also removes the Accounting Stop messasges. I just want to remove the ALIVE accounting packets.
Any ideas?
Ricardo
06-17-2008 12:20 PM
Actually the command you had mentioned earlier should be enough. Have you tried resetting the connection or re-adding the radius server to the router configuration after the change? Maybe that works.
Farrukh
