Troubleshooting Q.SIG Between Cisco 2811 and IPC Alliance.
Jun 16th, 2008
Having an issue getting layer 2 between Cisco 2811 and IP Alliance sollution.
Layer 2 keeps bouncing.
Posting config. from Cisco 2811.
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
description DID Range(s): xxxx;xxxx;xxxx
interface Serial0/0/0:15
description Trader Q.SIG Link One
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 300000
isdn protocol-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
Any suggestions would be helpful.
DTA
Paolo Bevilacqua Mon, 06/16/2008 - 11:45
  • Hall of Fame,
    Founding Member
Hi, likely you need clock source internal under controller E1 for this type of connection.
DELL ACORD Mon, 06/16/2008 - 11:52
I have another site where clock source line is working.
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20070320, FPGA: 20, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
MABOSOF5MVTR02#sh isdn status
Global ISDN Switchtype = primary-qsig
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
******* Network side configuration *******
dsl 0, interface ISDN Switchtype = primary-qsig
**** Master side configuration ****
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 189
Both sites are configured the same on the Cisco side. Only one building is bouncing.
Vendor has stated both sites are configured the same on their equipment.
DTA
Paolo Bevilacqua Mon, 06/16/2008 - 14:35
  • Hall of Fame,
    Founding Member
Setting clock source can resolve your issue so why not try it.
To look at circuit quality use "show controllers E1".
