AddH323Gateway AXL Example.
Jun 16th, 2008
Hello, Anyone have a working ADDh323Gateway?
I keep getting: "The specified Protocol Side is not valid for this device"
Which doesnt make sense because here is my ADD post... also here is a matching GET post showing the same protocol to protocol side to device relationship... what is going on?
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2000/10/XMLSchema-instance" xmlns:xsd="http://www.w3.org/1999/XMLSchema"> <SOAP-ENV:Body> <axl:addH323Gateway xmlns:axl="http://www.cisco.com/AXL/1.0" xsi:schemaLocation="http://www.cisco.com/AXL/1.0 http://192.168.200.200/schema/axlsoap.xsd" sequence="1234"> <gateway uuid=""><name>Test</name><description>Test</description><product>H.323 Gateway</product><model>H.323 Gateway</model><class>Gateway</class><protocol>H.225</protocol><protocolside>Network</protocolside><devicePoolName>Default</devicePoolName></gateway> </axl:addH323Gateway> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
GET
<gateway>
<uuid>{4091AAA2-AEDD-4856-9DA9-4E95B1C6777C}</uuid>
<name>Training01</name>
<description>Training01</description>
<protocolSide>Network</protocolSide>
<callingSearchSpaceName />
<networkLocation>Use System Default</networkLocation>
<networkHoldMOHAudioSourceId>0</networkHoldMOHAudioSourceId>
<userHoldMOHAudioSourceId>0</userHoldMOHAudioSourceId>
<loadInformation />
<versionStamp />
<traceFlag>false</traceFlag>
<mlppDomainId>-1</mlppDomainId>
<mlppIndicationStatus>Off</mlppIndicationStatus>
<preemption>Disabled</preemption>
<retryVideoCallAsAudio>true</retryVideoCallAsAudio>
<waitForFarEndH245TerminalSet>true</waitForFarEndH245TerminalSet>
<mtpRequired>false</mtpRequired>
<callerIdDN />
<callingPartySelection>Originator</callingPartySelection>
<callingLineIdPresentation>Default</callingLineIdPresentation>
<displayIEDelivery>false</displayIEDelivery>
<redirectOutboundNumberIE>false</redirectOutboundNumberIE>
<redirectInboundNumberIE>false</redirectInboundNumberIE>
<enableInboundFaststart>false</enableInboundFaststart>
<enableOutboundFaststart>false</enableOutboundFaststart>
<codecForOutboundFaststart>G711 u-law 64K</codecForOutboundFaststart>
<significantDigits>99</significantDigits>
<calledPartyIENumberType>Cisco CallManager</calledPartyIENumberType>
<callingPartyIENumberType>Cisco CallManager</callingPartyIENumberType>
<calledNumberingPlan>Cisco CallManager</calledNumberingPlan>
<callingNumberingPlan>Cisco CallManager</callingNumberingPlan>
<tunneledProtocol>None</tunneledProtocol>
<pathReplacementSupport>false</pathReplacementSupport>
</gateway>
risiprekel Mon, 06/16/2008 - 12:17
NEVERMIND.
CASE will get you everytime. Notice it should be protocolSide not protocolside.
