IOS Features and Licensing
Answered Question
Jun 16th, 2008
Being new to Cisco, I have found I have no clue as to their IOS licensing agreements. Am I correct in understanding their IPBASE IOS is a different license from their IPServices IOS? I want to utilize HTTPS in accessing the web server, am I correct in saying I need the IPSERVICES feature set?
Correct Answer by 4rmorris about 8 years 9 months ago
Guess I could have answered your actual question above :)
Actually you just need the ip base with crypto image to get the https server. Not sure if there's a licensing issue there, as you're not moving up to IP services, just enabling crypto features in the base IP image.
Assuming you have a 2800 series router the image name would be:
c2800nm-ipbasek9-mz.124-19.bin
The "k9" indicates crypto capability.
R.
Overall Rating: 5 (2 ratings)
4rmorris Tue, 06/17/2008 - 15:42
  • Bronze, 100 points or more
You're correct. You are technically licensed only for the version you purchased with your router. That hasn't stopped an awful lot of people from downloading more sophisticated feature sets and installing them (nothing in the device will stop you except for available flash/ram), but to be legit you should order the upgrade license from Cisco or your VAR. They'll charge you the difference, but you'll still go download it from CCO and install it on your device.
Check the feature navigator tool to identify which feature set you need to support your requirements:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Good luck!
Ryan Morris
CCIE #18953
kellyrudnick Tue, 06/17/2008 - 17:24
Thanks for taking the time to answer my question.
Am I correct in saying that the ipbasic IOS does not support HTTPS?
Correct Answer
4rmorris Tue, 06/17/2008 - 18:24
R.
