1721 as pptp vpdn server not working with pocketpc
Jun 16th, 2008
I have a 1721 configured as a DMVPN server, remote access ipsec vpn endpoint, and a pptp endpoint(specifically for remote access on a pocketpc). I am able to connect fine using a PC, and on the pocketpc the tunnel goes up, but whenever i try to send any traffic across the tunnel, the link drops. The funny thing is, If i configure my pocketpc to auto dial the vpn when certain addresses are put in internet explorer, and I go to one of those addresses, it works. however if i try to manually browse to another internal site, or file browse, the connectio immediately drops. My device is a treo 700w running mobile 5. I have included my config and debug log.
ryancolson Fri, 06/20/2008 - 18:12
I dont have access, can you post the details of the bug?
ryancolson Sun, 08/17/2008 - 15:20
I now have access. I looked up the bug and it looks like it pertains to the pix line. Does it also pertain to the IOS router line? Any resolution/workaround? Or any idea if/when there will be amobile anyconnect for the asa?
