Difference between WS-X6704-10GE or VS-S720-10G-3C 10G port
Jun 16th, 2008
Hi All,
We have a presales case, where the partner is asking the difference between VS-S720-10G-3C and the WS-X6704-10GE linecard . He is asking from the perspective of the performance and features comparison.
I would appreciate any information that anyone would be able to provide. Thanks for the help in advance.
Awaiting your reply,
Sinu Alias
Tom Randstrom Tue, 06/17/2008 - 18:29
  • Gold, 750 points or more
The following paper outlines deployment scenarios for the two cards if using them for Virtual Switch Links.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/prod_white_paper0900aecd806ee2ed_ps2797_Products_White_Paper.html
Brief excerpt:
“VSL-capable interfaces are required to create a VSL port channel. The current modules that support the formation of a VSL port channel are the 10 Gigabit Ethernet uplink ports on the Supervisor Engine 720-10G VSS (VS-S720-10G-3C/XL) and the Cisco 8-Port 10 Gigabit Ethernet Switching Module (WS-X6708-10G-3C/XL). (Refer to Figure 5.)
Figure 5. VSL-capable Modules
These interfaces contain new port ASICs that allow the VSH to be encapsulated on each frame forwarded out of the port and also support the ability to de-encapsulate VSH-tagged frames.”
It is a start...
