multilink config problem on 2811 router
Jun 16th, 2008
Hi,all
Thanks in advance.
is their any ios restriction for configuring multilink config on router 2811? i mean can i config multilink on ipbase 2811 router or i have to upgrade the ios version?
Pravin Phadte Tue, 06/17/2008 - 02:46
IPbase have a lot of restrictions and will not be able to used for fullest. Also what is the ios verison you want.
I would recommend advance service ios. Depending on your requirements.
Pravin
Sushil Kumar Katre Tue, 06/17/2008 - 04:12
Hi San,
As far as I know Multilink PPP does not requires any specific feature set. It should work fine with IP Base.
-> Sushil
