WLC module in 2811 not forwarding wlan traffic
Jun 16th, 2008
i have a WLC module inside a 2811 router. everything is working (ap connecting, administration) except traffic from WLAN is not leaving the wlc to the router.
The wlc is sending the dhcp packages to the default gateway (asa5510). See file wlc_dhcp.txt. The 2811 router isnt receiving the packace (at least a debug ip package didnt show it). Router interface config:
interface wlan-controller1/0
ip address 10.10.10.105 255.255.255.248
interface wlan-controller1/0.18
encapsulation dot1Q 318
no snmp trap link-status
bridge-group 18
bridge-group 18 spanning-disabled
interface Vlan318
no ip address
bridge-group 18
Whats wrong, why are the packages from vlan318 not reaching the router? Why are they not forwarded?
thanks, Martin
Juan Carlos Ari... Tue, 06/17/2008 - 07:48
Why don't you use 2811 router as your gateway instead of the ASA5510?? I think it will be easier, cause your problem could not be of wireless, it seems that's a problem with your ASA to access your inside network.
Hope this helps,
m.hierling Tue, 06/17/2008 - 21:43
Because the ASA is handling the WLAN Traffic (Firewall, VPN) and not the 2821. Also 6 WLC440x at our main locations are setup the same and they are working .
Martin
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
