DMZ access
dinesh.das
I am not able to access DMZ from outside. Attached the running config of firewall.
I think it might be some routing issue, any suggestions.
You mean this IP? 1.1.27..113
Try to add this in your DMZ ACL:
access-list DMZ1_access_in extended permit ip host 192.168.5.111 any
You can make it more secure after doing the initial testing.
Secondly fix your static as per my last post.
Farrukh
11 Replies 11
Some questions:
- Did you try to ping from outside your host in DMZ?
- When you try to access to host in DMZ do you see log messages on firewall?
- Did you set up the defaul gateway on host in DMZ?
Best regards.
Massimiliano.
1. i am not able to ping from out side to DMZ nat ip.
2. no
3. Yes
- From outside did you ping the ip address of the firewall's interface outside?
- From host in DMZ did you have access to hosts in Internet?
First of all your access-list is wrong:
access-list DMZ1_access_in extended permit ip host 1.1.27.113 any
access-list DMZ1_access_in extended permit icmp host 1.1.27.113 any
The 1.1.27.113 will never be seen on the DMZ side, it will only see the pre-nat local IP.
Secondly one of your static's is incorrect:
static (inside,outside) 1.1.27.101 192.168.5.101 netmask 255.255.255.255
This should be 192.168.1.101 OR
static (DMZ1,outside) 1.1.27.101 192.168.5.101 netmask 255.255.255.255
Thirdly, why have you put two default routes?
thanks a lot, i will implement the config as you said n try to ping from outside.
Regards.
all global ip are responding from out side, except DMZ NAT IP.
Farrukh
Thank you Farrukh, it is working now. I think the only problem was ACL_DMZ and that is what it was not comming out of the FW.
Just do some logging and icmp debugging in ASA then post it here.
did u try a telnet to a server.
Omair the issue is with the ACL and the static.
Farrukh
Agreed but I hope that he changed the config.
