Configure remote ping and set thresholds
Jun 17th, 2008
Is it possible to configure on a router or a switch an ping which pings every perhaps 10 seconds a target device and writes the response time in a mib variable? And can i set a threshold for this, that the device sends a trap, if the response time exceeds a limit.
How can i configure this? Do i config it with CLI or with snmpset? We have running HPOV and would be informed, if the ping takes to long.
Overall Rating: 3.8 (4 ratings)
b.hofmann Tue, 06/17/2008 - 23:07
Can you please send me the basic steps from a router, where you have configured it?
I want to ping a remote address every minute and it should run forever. If possible I want to create an threshold and get a trap it this threshold is exceeded. Or i can collect the data with HPOpenview, and compute it there. But i cannot find a IPSLA mib. Or what is the correct name for this mib.
An other question is, i have configured rtr on a router, and collect the data over the ping mib. But i unsure of the collected data, because i get data, which seems to be good, but sometimes they have the value 0, which is not in the range of the other values, because the data normally are between 7 and 16 milliseconds.
Thank you
b.hofmann Wed, 06/18/2008 - 00:38
I make a mistake,
i download the latest mib files from cisco, there is a SLAMIB available. But we are only using router with software 12.2, so i find only the rtr command.
I configurd the following:
rtr 1005
type echo protocol ipIcmpEcho 1.1.1.1 source-ipaddr 2.2.2.2
threshold 10
timeout 200
rtr schedule 1005 life forever start-time now
How can i read the results, i would collect the values with HPOpenview. What mibs are ther e neccessary. With the IPSLA mib i get no values.
Thank you
b.hofmann Wed, 06/18/2008 - 05:44
i didnot get any values, when i do a snmpwalk in this mib. But i get some values in the ciscoRttMonMIB. I see rttMonLatestRttOperCompletionTime, wher are values between 4 and 8. But every hour or so, I see a value 0, which I think is not really possible. Could this be the correct mib, or is it not possible.
Collin Clark Wed, 06/18/2008 - 05:51
  • Purple, 4500 points or more
That sounds right. I just checked mine (HTTP GET) and its OID is 1.3.6.1.4.1.9.9.42.1.2.10.1.1.11. I've never found a good way to correlate the RTT data with the OID. I usually do a SNMP Walk and view the raw stats on the router at the same time and whittle it down until I find the OID that matches the the value. I've never IPSLA ICMP, but a zero value does sound fishy, double check the OID.
b.hofmann Wed, 06/18/2008 - 21:33
I have done an snmpwalk and a grep for the value 12345, i didnot find something. Then i configure a rtr 12345 on the router, and did again a snmpwalk and a grep for 12345, and find only this 12345 in the rttmonmib. But the names which returns are not very helpful. What do you think is the meaning of rttMonLatestRttOperComletionTime? This is the only variable which is near the normal ping times, i mean between 3 and 10 milliseconds.
Collin Clark Thu, 06/19/2008 - 05:25
That's the OID you want. The router will append a number on the end though. For example mine has .10 for the DNS query and .11 for the HTTP GET.
In my router I did this-
<font size="2">3845-1#sh ip sla monitor statistics 10</p><p>Round trip time (RTT)   Index 10</p><p>        Latest RTT: <b>12 ms</b></p><p>Latest operation start time: 08:22:14.389 CDT Thu Jun 19 2008</p><p>Latest operation return code: OK</p><p>Number of successes: 40</p><p>Number of failures: 0</p><p>Operation time to live: Forever</p><p></font>
Then I SNMPWalked and got the following-
CISCO-RTTMON-MIB rttMonLatestRttOperCompletionTime.10 12
CISCO-RTTMON-MIB rttMonLatestRttOperCompletionTime.11 24
b.hofmann Thu, 06/19/2008 - 05:48
This helps me very much.
I have done a sh rtr operational-state, and see the same values, which are in the snmpwalk. But have you any idea, why is sometime the value 0.
Perhaps i do the query in the same moment, when the measure is started. But how can i correct this problem?
Collin Clark Thu, 06/19/2008 - 07:23
What exactly is your SLA config?
b.hofmann Thu, 06/19/2008 - 21:12
This is configured on the router:
rtr 1005
threshold 10
timeout 200
Collin Clark Fri, 06/20/2008 - 11:35
what version of IOS? I'll load it on lab router and see what I get.
Collin Clark Fri, 06/20/2008 - 11:51
I just set it up and the OID is rttMonLatestRttOperCompletionTime.1 with the last 1 being the SLA entry number. It is accurate. I'll graph it for awhile and see if I get any zeros. I am running 12.4(15)T1. The graph is showing zeros (until I fixed it to graph for msec instead of sec), but the numbers match.
b.hofmann Sun, 06/22/2008 - 23:20
This is the version from the router:
IOS (tm) s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD7b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 08-Dec-06 12:51 by ccai
Image text-base: 0x4002100C, data-base: 0x42320000
