MSFC3 performance fallback bridging
Jun 17th, 2008
I consider to implement fallback bridging on
a Catalyst 6500 with WS-SUP720-3B (MSFC3+PFC3B).
This is a solution for non-routable (IBM) traffic that
needs to be forwarded between the 6500 VLANs.
I am concerned that the bridging may affect
the performance of the MSFC3 however.
Should I be concerned at all?
What is a safe number for the aggregate bridged
traffic throughput (for MSFC3)?
Any counter-indications for fallback bridging
MSFC3 in general?
Patrick
Anonymous (not verified) Mon, 06/23/2008 - 07:08
You must configure bridge-groups to do any bridging.Fallback bridging means you are routing IP and bridging the other stuff
(AT, IPX, SNA). Use the vlan-bridge protocol. Eg:
int vlan 10
ip add 10.1.1.1 255.255.255.0
bridge-group 1
bridge 1 protocol vlan-bridge
