BRI Isdn Voice Ports locking up
Jun 17th, 2008
I have an issue where the BRI ports are not always been released after making a call they get permanantley stuck in the state. Details below:
sh voice call summ
PORT CODEC VAD VTSP STATE VPM STATE
0/1/0.1 - - -
0/1/0.2 - - -
0/1/1.1 - - -
0/1/1.2 - - -
0/3/0.1 - - -
0/3/0.2 None - S_SETUP_FAIL S_TSP_WAIT_RELEASE
0/3/1.1 - - -
0/3/1.2 None - S_SETUP_FAIL S_TSP_WAIT_RELEASE
IOS version is 12.4(1)exp.
Config for the BRI is :
nterface BRI0/2/0
description QSIG Trunk in TE mode
no ip address
isdn switch-type basic-qsig
isdn overlap-receiving T302 3000
isdn tei-negotiation remove
isdn point-to-point-setup
isdn incoming-voice voice
isdn global-disconnect
isdn send-alerting
isdn sending-complete
isdn static-tei 0
isdn timeout-signaling
isdn skipsend-idverify
I think this is looking like a software bug but was wondering if anyone has ever seen this.
Any help appreciated.
Cheers
Kev
paolo bevilacqua Tue, 06/17/2008 - 02:50
  • Hall of Fame,
    Founding Member
I see that youre, using 12.4(1) something. Please upgrade to a minimum of 12.4(3j). If you will be using CME and need new features, upgrade to 12.4(11)XJ4.
kevinhobson2000 Tue, 06/17/2008 - 03:59
Thanks for the advice i will upgrade the software and see if it resolves this.
Cheers
Kev
kevinhobson2000 Tue, 06/17/2008 - 23:02
I have attached some debug output for VTSP, CCAPI inout and isdn events. I am getting this error.
Jun 17 15:57:15.909 BST: ISDN **ERROR**: Module-CCBRI Function-_SetNewChan Error-Cannot get an idle channel from chan mgt. Data-
0, 2
but this could be just because there are no channels available due to the voice ports not being released.
Cheers
Kev
paolo bevilacqua Wed, 06/18/2008 - 00:32
  • Hall of Fame,
    Founding Member
Which experimental software? Upgrade to 12.4(3j) as suggested above and your issues should be should be solved.
paolo bevilacqua Wed, 06/18/2008 - 01:18
  • Hall of Fame,
    Founding Member
There are many. Upgrade to avoid them all.
paolo bevilacqua Wed, 06/18/2008 - 04:01
  • Hall of Fame,
    Founding Member
No problem.
Please remember to rate useful posts.
lohmannt Mon, 11/10/2008 - 05:35
Kev -
I am getting the same error:
ISDN **ERROR**: Module-CCBRI Function-Unknown error function Error-Unknown or unexpected event received. Data- 7, 500
But I am on code: (C2800NM-SPSERVICESK9-M), Version 12.4(19)
__________________
Did upgrading solve your issue? and what code are you running?
Thanks - 3sa
gsidhu Fri, 04/16/2010 - 08:32
I'm getting the same issue:
This is for a new install. I'm running 124-24.T3 on a Cisco 1861 over BRI using H323
Is this errot message down to a software issue or proble at the Telco end?
paolo bevilacqua Sat, 04/17/2010 - 07:23
  • Hall of Fame,
    Founding Member
Try 12.4(22)YB5.
kevinhobson2000 Mon, 04/19/2010 - 02:37
Its been a long time since i had this problem but if i remember rightly the IOS and the PBX software had to be upgraded to resolve the issue in my case.
Kev
gsidhu Sun, 04/25/2010 - 08:47
Before I installed this version I noticed that I was no longer getting the same error message that you responed to. The issue had been escalated to the Service Provider so I'm wondering if they made any changes.  Instead the gateway was sending disconnect with 'Network out of order' message.
This turned out to be a simple configuration error. (I had missed the h323 interface statements).
Thanks to all of you who tried to help.
