Arp inspection
Jun 17th, 2008
I enable arp inspection and have a acl for mapping IP to MAC and apply it to VLAN 200.
What happen if a packet with IP is not in the ACL is received on VLAN 200 ? Does the switch flood it or drop it ?
The switch is 4500.
bwilmoth Mon, 06/23/2008 - 07:09
on the awitch, enter the following global configuration command:
"ip arp inspection vlan " where the vlan number you are using
- clear the arp table on the host
Once doing this you will notice that "show ip arp insoection vlan " is enabled/active.
ralphcarter Mon, 06/23/2008 - 12:25
It will drop it, you will get no connectivity until you create the appropriate binding.
