Secondary IP Address
Jun 17th, 2008
Quick question. Have to add a subnet but am out of open fast ethernet ports on ouor router. I have an existing connection between 2 of our routers. If I add a secondary IP address on each side of this connection will I be able to route through the secodnary IP's.
Will arp get cached for this new subnet on the routers? Thanks
Pravin Phadte Tue, 06/17/2008 - 03:44
  • Silver, 250 points or more
Yes the connection should be able to route using the secondary ip address.
Not so sure about the arp but u guess the devices with secondary ip address will get cashed with the ip address range in secondary.
Hope this helps
Pravin
