Rick Morris Tue, 06/17/2008 - 06:36
  • Silver, 250 points or more
If a call needs to connect to a CCME at a different location it must be built and the TFTP server must be from that location.
For instance our HQ office, we also needed to open the IP for the phone in the firewall to allow traffic to flow, calls to process.
What will happen is the IP address from that location will be given to that device so it will be on the same subnet at that point.
paolo bevilacqua Tue, 06/17/2008 - 06:36
  • Hall of Fame,
    Founding Member
Yes, there is no problem in doing that. Only, you want to properly setup your routing so that any subnet where are phones, can communicate with all the others. If you cannot do that, configure "mtp" under the remote ephone.
laposilaszlo Tue, 06/17/2008 - 07:13
There are some special requiremens for this to work on a public internet VPN.
I heard that the round trip time must be under certain value.
Thak you again,
laszlo
paolo bevilacqua Tue, 06/17/2008 - 07:58
  • Hall of Fame,
    Founding Member
Hi, I have sites with RTT of like 900 ms (vsat) and they work just fine.
Thanks for the appreciation and good luck!
