call notification second line ccm4.2
Answered Question
Jun 17th, 2008
Dear all,
I have a 7961 setup with 2 separate lines. if the person is using the first line and recieves a call on the second line, the person only hears one beep and the phone button is blinking.
is there a way that you can hear a beep like every 10 seconds?
regards,
Gerard
Correct Answer by chris.fortner about 8 years 7 months ago
You can change the incoming call alerting on the line page to say ring, beep, etc... I would check there and see if any of those work for you!
Overall Rating: 5 (1 ratings)
rob.huffman Tue, 06/17/2008 - 06:21
Hi Gerard,
Sadly there is no way to change this behaviour :( Have you changed the Device setting "Auto Line Select" to enabled so the user gets the new call screen display?
Hope this helps!
Rob
Correct Answer
chris.fortner Tue, 06/17/2008 - 11:11
gerard van rij Wed, 06/18/2008 - 01:39
thanks Chris,
although I would prefer to have a beep which would repeat itself every x seconds. I've selected that the phone will ring if someone calls.
so.. it solved my problem.. thanks
