06-17-2008 05:30 AM - edited 03-10-2019 03:54 PM
ip tacacs source-interface command is not availabe on WS-C3560G-24TS ios 12.2(44)SE C3560-ADVIPSERVICESK9-M. it is available on 12.2(40)SE C3560-ADVIPSERVICESK. any ideas?
06-17-2008 06:09 AM
You are hitting a known bug: CSCsm28901. The command support was left out. It will fixed in 12.2(44)SE2 and newer code versions. That release is not yet available but here is the workaround.
Workaround:
Configure the source-interface under the TACACS server group.
Example:
Switch(config)# aaa group server tacacs+ test
Switch(config-sg-tacacs+)# ip tacacs source-interface Vlan1
Switch(config-sg-tacacs+)# exit
Please let me know if you have any further questions.
~JG
Do rate helpful posts
06-17-2008 06:10 AM
Workaround:
Example:
~JG
