Troubleshoot DFM 2.0.10
santipongv
I am troubleshooting DFM problem on a managed network device. I was told to issue the command, "dmctl -s DFM get Router::<ipaddr>". However, I got a message, "dmctl: Could not attach to 'DFM': Login to Domain Manager failed; permission denied." What credentails I can use to make this to work? Thank you in advance.
I mean, does it show up by hostname or IP? That is what you need to pass to dmctl.
11 Replies 11
Joe Clarke
Typically if dmctl prompts you for a username or password, it is admin/admin. However, the actual username and password can be found in NMSROOT/objects/smarts/conf/clientConnect.conf.
I did try admin/admin, but it didn't work. I didn't see the actual username and pasword in clientConnect.conf file. Please advise.
Without seeing your clientConnect.conf, I cannot comment. All I know is it will be in there.
#:1.0:4
# The first line indicates that field number 4, the password, should be
# encrypted. It must be the first line in the file. The lead character, '#',
# is an essential part of the directive. Once the file is encrypted, a
# second line starting with "# DO NOT ALTER " is
# inserted into the file. It provides data for an integrity check. Do not
# delete or alter this line.
# clientConnect.conf
# Client outgoing authorization file
# This file defines the authentication credentials that clients will send
# to servers. Brokers do not use this file; see brokerConnect.conf.
# format:
# login user : target : InCharge user name : password
# The fields 'login user' and 'target' may be wildcard patterns.
# When a client other than a console wishes to connect to a server, it reads
# the lines in this file in the order written, searching for a line whose
# 'login user' matches the user running the client and whose 'target' matches
# the name of the server being connected to. Only the first matching line is
# used (but see the discussion of below.)
# Once a line is located, its 'InCharge user name' and 'password' are sent
# to the target as credentials.
# Use '\' as an escape character.
# Comment lines start with # or //. Leading and trailing spaces are ignored
# in each field.
# Some fields may also contain special values:
# Field 'target' may contain or ~. The value
# specifies the Broker; ~ specifies all servers, but not the
# Broker.
# Field 'InCharge user name' may contain . The user name under
# which the current process is logged in is sent as the 'InCharge user name'.
# Fields 'InCharge user name' and 'password' may contain . If the
# program is attached to a terminal, the system will prompt the user for
# the corresponding value. Lines containing a are skipped by
# programs that are not attached to a terminal, even if they would otherwise
# be selected. (A later line matching the 'login user' and 'target' will be
# used.)
# is used by the target to authenticate legacy clients.
# Example:
# admin :InCharge : :
# goodop :~: operator : doit
##################### Program and User Access to Broker #####################
# By default, Brokers are operated in Nonsecure mode, using the well-known
# credentials BrokerNonsecure/Nonsecure. There is a line corresponding to
# this one in serverConnect.conf. This section must come before the "User
# Access" section to avoid prompting interactive users for the Broker password.
# If you use a secure Broker and wish to prompt interactive users, combine
# this section with the Program Access section below.
*::BrokerNonsecure:Nonsecure
##################### User Access #####################
# All interactive users get prompted. Note that because it comes first, and
# specifies the match-all '*' for both 'login user' and 'target', this line
# will always be selected for all interactive users, even if they would
# otherwise match a later line.
##################### Program Access #####################
# NOTE: admin has full access. You should change the password! When you've
# done so, change the corresponding line in serverConnect.conf. This section
# must come after the "User Access" secion or it will be used for all
# connection attempts, including interactive ones.
#This is the line we care about
I did try admin/admin again, this time I got the below message although it is the managed IP address.
dmctl -s DFM get Router::208.4.60.1
Server DFM User: admin
admin's Password: XXXXX
Router::208.4.60.1: No such object
Then this device (208.4.60.1) is not a router. Under what DCR device type category does it appear?
It appears as 7304 router. This is the managed IP address for this device.
How does this device appear in DFM?
Under "All Known Devices in Inventory Services".
It shows up as hostname. It got output now. Thank you.
