Jun 17th, 2008
Does the below show version qualify this router as a 2801 VK9 router? It is missing the WIC cards, but it is the base router that I need to confirm:
Router#show ver
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.3(8)T8, RELEASE SOFTWARE (fc1)
Technical Support:
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 06-Apr-05 12:34 by yiyan
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
Router uptime is 0 minutes
System image file is "flash:c2801-spservicesk9-mz.123-8.T8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
*Jun 17 15:43:35.695: %SYS-5-CONFIG_I: Configured from console
[email protected].
cisco 2801 (revision 5.0) with 236544K/25600K bytes of memory.
Processor board ID FTX0928W02C
2 FastEthernet interfaces
2 DSPs, 24 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Paolo Bevilacqua Tue, 06/17/2008 - 07:52
Hi, K9 only means there is some encryption software in the IOS that is loaded, so yes you are running a K9 IOS version.
Routers all the same. The difference is made by the IOS that is loaded.
Sushil Kumar Katre Wed, 06/18/2008 - 06:16
Hi Erik,
If your query is whether the router you have is according to what you have ordered "CISCO2801-V/K9", the answer is yes.
What's shipped with this bundle CISCO2801-V/K9 -
IOS SP Services
64 MB Flash/256 MB DRAM
What you have -
IOS SP Services
Check in show mod output if you have PVDM2-8
If your original query is something else let us know.
-> Sushil
Sushil Kumar Katre Wed, 06/18/2008 - 07:16
I guess 2 DSPs = PVDM2-32
PVDM2-16 = 1 DSP
And this is the reason why I asked him to check the show diag output to check which PVDM he has. By default with the bundle he ordered PVDM2-8 should come unless he has ordered a factory upgrade for PVDM or ordered additional PVDMs.
-> Sushil
