CCM 4.2.(1)sr1 question
Jun 17th, 2008
Hi to all,
I have 3 CCMs, one Publisher and two Subscriber. when i try to get into CCM Administration page with CCMAdministrator user i can into the Publisher and one Subscriber but in the other one can not, why?, do i have to start some service?,
Best regards,
Alberto
chris.fortner Tue, 06/17/2008 - 09:47
RDP to your server and open the SQL Enterprise Manager. Click on your server and list the databases. Check the replication state and make sure there are no errors!
Let me know the results!
Jaime Valencia Tue, 06/17/2008 - 09:59
run the ccmpwdchanger to reset the ccmadministrator pwd and try again
javalenc
if this helps, please rate
alberto.orden Tue, 06/17/2008 - 23:35
Hi javalenc,
But i don not want to change the CCMAdministrator password, and is just in one subscriber.
Alberto
mlundbom1 Wed, 06/18/2008 - 02:22
Run the tool, you can set the same password again :-) It does sound like a pwd-synch issue.
Best regards,
/M
alberto.orden Wed, 06/18/2008 - 07:23
I ran the tool in the publisher changing the password and now i can not get into any of them.
Need help,
best regards
alberto.orden Thu, 06/19/2008 - 08:08
I solve it,
i saw in the cuom 2.0.3 an event of the call managers (DC Directory Server windows service was stopped), i started the service and everything ok.
Thanks anyway
best regards,
Alberto
