Custom HUM reporting
Jun 17th, 2008
I would like to setup a report that will track the number of B channel interfaces for a PRI that were active for a particular day as well as identify the number of B channels that were active at the same time.
The overall goal is to proactivley montior the B channel utilization of PRI's for a given site to see if additional PRI's are needed.
All ideas are appreciated. Thanks.
Joe Clarke Tue, 06/17/2008 - 08:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What type of device, and what IOS version?
beschbach Tue, 06/17/2008 - 09:18
The device is a 3825 router running c3825-advipservicesk9-mz.124-15.T1.bin
Joe Clarke Tue, 06/17/2008 - 09:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You could create a poller looking at cpmActiveDS0s (1.3.6.1.4.1.9.10.19.1.1.4) for your PRI instance. You could then establish thresholds if the count of active DS0s becomes too high.
