Jon Marshall Tue, 06/17/2008 - 09:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Which major version of IOS are you looking for. I have just checked Feature Navigator and at random picked 12.4(10) IP 3DES and it supported IP SLA.
Feature navigator really is the best thing to use.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Jon
mjhagen Tue, 06/17/2008 - 09:40
I currently user 12.3.26 Enterprise and ip sla is not there. I looked in feature navigator and only version I found was 12.2-31.sb10. I am not sure that it will support NPE-G1
Jon Marshall Tue, 06/17/2008 - 09:46
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Mike
According to Feature Navigator 12.3(26) Enterprise does support IP SLA or at least these
IP SLAs - Application Performance Monitor (APM)
IP SLAs - DHCP Operation
IP SLAs - Distribution of Statistics
IP SLAs - DLSW+ Operation
IP SLAs - DNS Operation
IP SLAs - Frame Relay Interfaces
IP SLAs - Frame Relay Operation
IP SLAs - FTP Operation
IP SLAs - History Statistics
IP SLAs - HTTP Operation
IP SLAs - ICMP Path Echo Operation
IP SLAs - MPLS VPN Awareness
IP SLAs - One Way Measurement
IP SLAs - Path Jitter Operation
IP SLAs - Reaction Threshold
IP SLAs - Scheduler
IP SLAs - SNA LU2 Echo
IP SLAs - SNMP Support
IP SLAs - TCP Connect Operation
IP SLAs - UDP Echo Operation
IP SLAs - UDP Jitter Operation
Is there something else you need.
Jon
mjhagen Tue, 06/17/2008 - 09:50
Yeah thats what feature navigator says.
This is what my router is running:
System image file is "disk2:c7200-js-mz.123-26.bin"
IP SLA is not there
Jon Marshall Tue, 06/17/2008 - 10:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Mike
Sorry, don't have a 7200 to test on.
One quick check, apologies if you have already done this.
7200(config)# ip sla monitor 1
or
7200(config)# rtr 1
Jon
mjhagen Tue, 06/17/2008 - 10:23
I did try ip sla monitor 1 not there
rtr 1 is there. Looks like syntax is different.
