sip server through site to site VPN
Jun 17th, 2008
Dear all,,
I have a site to site vpn .. in my site i have UC 500 and in the other site i have ASTRERSIK and have a SIP server , I want to rigester to this server and can call th phone they have.
below the config and some debug
when i run DEBUG CCSIP ERRORS i have atrange erro (Jun 17 12:37:09.163: //96/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Class 4xx Method Code 100 received for REGISTER)
any body understand this error.. and do i need a translation rule?
Overall Rating: 5 (1 ratings)
chris.fortner Tue, 06/17/2008 - 10:48
you need to turn on sip registration :
voice service voip
registrar server expires max 600 min 60
Try this and see if you error goes away!
motasemkhater Thu, 06/19/2008 - 04:24
Thank u man the errors goes away ..
any way i was doing somthing stupied by trying to dial from my 7940 phone without change it to sip ..i have tried alot of cisco guides to convert 7940 to sip but nothing worked out may be its the UC500.. attached is my running config ..
in my phone when i check status from Network configuration i have VERSION 8.0(5.0)
i follow this link
and do every step to change SCCP to SIP
but nothing work out... i dont know if i need to downgrade from SCCP 8.x to 5.x then upgrade to sip 4.x ... and is the firmware in call manager same as call manager express or uc500
motasemkhater Thu, 06/19/2008 - 04:32
attached the SHOW telephony service ..u can see load 7960-7940 P00305000500
but my phone have in firmware version
Appload ID : P0030800050
bootlood ID: PC0303010200
Version 8.0(5.0)
and all my tries to change to SIP was done while the phone is connected to the uc500
