4402 Network Routes
Jun 17th, 2008
I am having a tough time with setting up the "Network Routes" on our 4402. I am trying to add our ohter subnets but I get the "gateway needs to be on the service port" message?
My Service Port interface is on a dot 3 so why when I add a dot 8 to the "Network Routes" would I put a dot 3 as the Gateway IP Address? the gatewy should be dot 8.
I also noticed that the Service Port is optional, perhaps I will not configure this for now?
ericgarnel Tue, 06/17/2008 - 11:55
  • Gold, 750 points or more
Perhaps it is because that the management and dynamic ports are actually on a switchport that it itself does not "understand" routing. You are basically trying to tell the controller to use the same physical interface for trunking and routing.
whitefalcon6 Tue, 06/17/2008 - 12:11
What i'm saying is if I add a dot 8 to the network routes the gateway HAS to be dot 8, not a dot 3 just because that is the subnet that the service-port is on.
How do I get around this?
ericgarnel Thu, 06/19/2008 - 05:48
You may need to implement router(s) between the two in order to make the route tables meet your needs.
Trending Topics - Security & Network
