WCS Import CAD
Jun 17th, 2008
When I am trying to import a CAD into WCS and I keep getting a communication error from the server and the CAD will not import. Anyone heard of this?
1 vote
didyap Mon, 06/23/2008 - 06:34
Import of CAD files (.dxf / .dwg) fails with error of 'Invalid file type.' If the pc that the CAD image resides on or is imported from has an application that supports or handles CAD files. To solve the problem Try importing the CAD file from a pc that does not have an application that supports CAD files.
dennischolmes Mon, 06/23/2008 - 12:13
THe other thing you can do is disassociate the dwg/dwf file extensions from the application that they are opened with in Windows to none.
krengasw Thu, 07/03/2008 - 01:43
check these(msvcp71.dll & dwmapi.dll) files present under
if not present download and add to above mentioned location.
After copying the files to the above mentioned locations, Restart WCS and CAD files will be added successfully.
Hope this will solve your problem.
enazevedo Mon, 02/25/2013 - 06:28
Hi guys!
I have the same issue, and see on the internet many explanations with this solution, but no one tells: Where can i download this files?
Trending Topics - Security & Network
