CME Conference Configuration
Jun 17th, 2008
Hello All,
I have configured the hardward conference on CME for AD-Hoc. The conference profile is not able to register with CME. Please see the attached configuration & the error message below.
SCCP Admin State: UP
Gateway IP Address: 10.199.108.1, Port Number: 2000
IP Precedence: 1
User Masked Codec list: None
Call Manager: 10.199.108.1, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.199.108.1, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 10
Reported Max Streams: 6, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: NOT_REGIS_WITH_CCM
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 2
Reported Max Streams: 32, Reported Max OOS Streams: 0
Also, Attached is the debug of sccp details log.
Your help is always appreciated.
Yogesh Mhatre
chris.fortner Tue, 06/17/2008 - 14:53
You are missing some command under the telephony-service configuration.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. conference hardware
5. transfer-system full-consult
6. sdspfarm units number
7. sdspfarm tag number device-name
8. sdspfarm conference mute-on mute-on-digits mute-off mute-off-digits
Step 8 you are missing!
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html
chris.fortner Tue, 06/17/2008 - 14:58
And I don't see the global command "dspfarm" to enable the dspfarm. I don't think your dspfarm is running!
yogesh.mhatre Wed, 06/18/2008 - 06:56
Hello Chris,
Thanks for your reply.
I tried the dspfarm command & the missing command, still i receive the same message.
Appreciate your help.
Yogesh Mhatre
