interoperability cisco and brocade
Jun 17th, 2008
i need to integrate two fabric in only one fabric, two switch are
cisco MDS 9216I and 9216a, and other fabric are two brocade 4100,
both fabric currently are in prodution, i need to know what is the
best procedure for to do this interoperability Between cisco and
brocade with the less posible disruption.
i believe that the best mode is interop 3, so i need to do a merge between the two fabric and to unify the two configurations, could you give me your recomendation in this case? atach to this post is the two suportshow
and a graph of the solution.
thank you for your help
ebreniz Mon, 06/23/2008 - 06:35
  • Silver, 250 points or more
You can run native BRCD interop mode 2/3 with the MDS. You would need interop mode and we all know that Brocade does not really like doing it with Cisco and might not even support that config. IVR is not possible as the switch is a 9124 that is not capable of that feature. One switch would become the principal switch so that means the two can't really be managed by different organisations.
I would find another way of sharing the data especially if the "customers" want their own management facility. RBAC is possible in some way or another on both switches (if you believe Brocade) but it is not a good solution.
techhelp24 Mon, 06/23/2008 - 19:55
Hi migvzla3011,
you must work on the Cisco site with Mode 3, and the Brocade core must be set with "PID 1"
Trending Topics: Storage Networking
