Multiple Call Park's
caflippo76_2
I have an IPCC agent who parks multiple calls at once. The park number of the last call parked is what is on the agents 7970 phones display. That last call parked is retreived and call completed but the other call park numbers don't automatically display on the phone. How can I allow my IPCC agents to view the park numbers of the calls they parked?
Any help is much appreciated.
5 Replies 5
thisisshanky
Level 11
Level 11
Why does these calls have to be parked in the first place ? Couldnt these calls be queued ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
depending on which version you have you might want to use directed call park and BLF, you can configure this per user if needed
it's available in 4.2(x) and 6.(x) only, if you do not have one of those versions then i would consider AC for that or even better, UCCX as mentioned by shanky
javalenc
if this helps, please rate
java
Yes, you are correct. These calls are already coming out of the qeue. For some reason the agent(s) still find it nessasary to park multiple calls at a time.
The directed call park/BLF seems like the simplest solution. Is there an issue with using standard call park on other phones on same cluster along with directed call park?
no, there is no issue. actually you can have both on the same phone as the DNs are going to be unique within your dial plan. so he can have his dedicated directed call park slots and also regular call park if needed
javalenc
java
Thank You!
