UCM 6.1 Xcode/Conf Resources
Jun 17th, 2008
cannot get hardware conference/transcode resources to register. sccp shows up, cause code is tcp_conn_error. Used same process I use in CM4.2 DSP's are up.
no sccp/sccp doesnt help. Selecting IOS Enhanced in UC6.1 Thoughts are welcome
thisisshanky Tue, 06/17/2008 - 13:33
  • Purple, 4500 points or more
Can you paste your SCCP configs
balitewiczp Tue, 06/17/2008 - 13:38
CNHKGNRT301#sho sccp
SCCP Admin State: UP
Gateway IP Address: 172.21.125.130, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.5.139.197, Port Number: 2000
Priority: 2, Version: 5.0.1, Identifier: 2
Call Manager: 10.5.135.196, Port Number: 2000
Priority: 1, Version: 5.0.1, Identifier: 1
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 2
Reported Max Streams: 8, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 32, Reported Max OOS Streams: 0
CNHKGNRT301#sho sccp ccm gr 1
CCM Group Identifier: 1
Description: None
Binded Interface: Loopback99, IP Address: 172.21.125.130
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated CCM Id: 2, Priority in this CCM Group: 2
Associated Profile: 2, Registration Name: APHKXCODE
Associated Profile: 1, Registration Name: APHKCFB
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 3, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: GRACEFUL, Switchback Method: GRACEFUL_GUARD
Switchback Interval: 10 sec, Switchback Timeout: 7200 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
sccp local Loopback99
sccp ccm 10.5.139.197 identifier 2 priority 2 version 5.0.1
sccp ccm 10.5.135.196 identifier 1 priority 1 version 5.0.1
sccp
sccp ccm group 1
bind interface Loopback99
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register APHKXCODE
associate profile 1 register APHKCFB
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
maximum sessions 4
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
chris.fortner Tue, 06/17/2008 - 13:44
What are the names of the resouces in your callmanager? Are they APHKXCODE and APHKCFB?
thisisshanky Tue, 06/17/2008 - 13:43
Does the names match in CUCM as specified in IOS configs
chris.fortner Tue, 06/17/2008 - 13:45
You would think to CCIE Voice guys would have something better to do!!!
Also - Use standard IOS and not enhanced!
balitewiczp Wed, 06/18/2008 - 05:54
Yep, names match exactly. Tried Standard, same problem. Is "no sccp / sccp" the correct way to reset from cli? Maybe its an IOS problem. version is 12.4(9)T7
