Device not reachable using telnet from LMS
Answered Question
Jun 17th, 2008
I'm trying to add a device to the DCR. We can access it using telnet but when LMS 3.0.1 says it's not reachable.
If I launch a "Management Station to Device" it says telnet OK. If we launch "Check device credentials" it says "Device not reachable" using telnet and we have insert the credentials several times so it's impossible to insert them wrongly.
What can be happening?
Thanks.
Correct Answer by Joe Clarke about 8 years 9 months ago
Have you entered correct SNMP credentials for this device so that RME can properly manage it, and determine the correct device package to use?
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 06/17/2008 - 14:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
cmartinvalle Thu, 06/19/2008 - 01:16
Thank you very much.
The device did not haver configured SNMP. I thought devices could be managed also using telnet enable password.
Regards.
