B ACD Dial by Extension to Default
Jun 17th, 2008
Anybody know if is possible to set one option to the default using bacd script?
I need that when the caller enter in the AA Pilot, the Option dial-by-extension, be the default option for the callers, without dial the dial-by-extension menu option.
I try to send this information using the dial-peer like this:
dial-peer voice 2801 pots
description ### AutoAttendant ###
service cme-aa
paramspace cme-aa optionSelected 3
incoming called-number 55102800
port 0/1/0:15
But not work as well.
Tafari Lima
paolo bevilacqua Wed, 06/18/2008 - 04:18
  • Hall of Fame,
    Founding Member
you need to modify the script to do that.
tafari.lima Wed, 06/18/2008 - 07:43
But how can I do that? I will need to recompilate the script to do this?
Thanks for your anwser.
paolo bevilacqua Wed, 06/18/2008 - 14:15
  • Hall of Fame,
    Founding Member
I correct myself, you don't need to modify the script. Just config drop-thout mode to dial by extension. Check B-ACD/AA doc for how to configure drop-troutgh mode.,
