Router 800 series support loadBaland and failover ?
Jun 17th, 2008
dear All,
Could you let me know please!!!
I would like to know on Router 800 series can support loadbalance and failover or not?
spremkumar Tue, 06/17/2008 - 21:35
Hi David
what kinda load balance and failover you are looking at ?
can you be more specific about the requirement you have out there in your network ?
rechard_david Tue, 06/17/2008 - 22:47
dear Spemkumar,
Thanks you for your question.
i would like to know this product can suppport load banland and failover or not?
Load Balance ( i mean i have 2 ISP and the both ISP share 50%) and failover ( i mean i have 2 ISP and ISP1 active and ISP2 Backup whne the ISP1 down, ISP2 will be up automatic)
Best Regards,
spremkumar Tue, 06/17/2008 - 23:58
hi david
if you are looking at load balance with routing protocols such BGP then i dont think 800 series will be able to do that.
But as far as redundancy/failover is concerned with 2 ISP and with NAT options you can do with 800 series routers.
With normal NAT and 2 ISPs i dont think you will be able to get the desired result of load balancing.
But i think you can segment your local lan network and do a policy based NAT which can take care of your loadbalancing (one segment of your lan using ISP1 and the other segment using ISP2).
