WAAS - NAT between CM and WAE
Jun 17th, 2008
Seem to have a problem with nat/firewall between CM and WAE. Configuration commands issues via CM GUI do not make it to the WAE (checked via CLI).
I configured the NATed IP address ofor the WAE in device activation screen NAT section. I am running WAAS 4.0.19.b14.
Any ideas please?
DG
Zach Seils Wed, 06/18/2008 - 07:49
  • Cisco Employee,
DG,
Is the WAE status Online in the CM?
Zach
d.gabo Wed, 06/18/2008 - 15:15
Zach,
The WAE s had registered successfully wit the CM and its status is on line. It looks lie CM does not recognise the NAT entry for the to communicate with it using its real address, which i assume is derived from the registration.
Configuration snapshots are in the file attached. The device behind FW/NAT is 172.21.227.205
Zach Seils Thu, 06/19/2008 - 07:55
  • Cisco Employee,
Looks like the CM tries to push the change using the WAEs real IP address, which fails. However, in my lab, the configuration change is picked up by the WAE on the 5 minute refresh cycle (when the WAE contacts the CM).
Are you not seeing the configuration change update after 5-10 minutes?
Zach
d.gabo Thu, 06/19/2008 - 14:28
Zach,
I may have been too impatient, expecting an instant push of config changes from CM to WAE. The CM already has the NATed address of WAE and I would have thought should not rely on refresh cycle to pick it up. I did not realise that WAE pulls configs from CM.
I'll give it a try.
Zach Seils Fri, 06/20/2008 - 21:13
  • Cisco Employee,
DG,
Can you uncheck the 'Use WAE's primary IP Address' box and retest?
Zach
