Duplex mismatch change does not reflect in sh interface type command
Jun 17th, 2008
I changed the Duplex setting on an Interface in a Switch to full . the startup and running config reflect the change from half to full, but the Show interface command still shows it as half. Why is it so ?
spremkumar Tue, 06/17/2008 - 22:25
  • Red, 2250 points or more
hi
In which switch model you are trying to change the same ?
Whats the os version currently running in the switch ?
can you post the output of show run/startup as well as show interface commands here ?
regds
glen.grant Wed, 06/18/2008 - 04:12
  • Purple, 4500 points or more
Did you hardcode the speed also ? Post a "show interface status" here so we can take a look at it. You could also bounce the port and see if it changes.
