Warning message
BGP 2 Sites /19 Routes - more specific routing?
Jun 18th, 2008
Hello!
We have 2 sites with 7500 Routers and BGP
We own a /19 Network
Our Upstream Provider wants me now for load reduction to accept 2 times the same network 1.2.3.4/19 on both sites.
I should then enter the "real" networks on the routers via "more specific" routes.
1 want 1 /24 network to terminate on site 1 the rest on site 2
I have no idea what my upstream provider means..
http://www.cisco.com/en/US/docs/ios/12_0/np1/configuration/guide/1cbgp.html#wp8238
thanks!
marco
shivlu jain Wed, 06/18/2008 - 00:09
  • Silver, 250 points or more
It's often useful to conditionally advertise some routes to upstream neighbors-
particularly if you are trying to control which link is crossed by traffic destined to a
particular network.BGP has the capability to conditionally advertise routes;
As per me you can use if the one link down automatically the /24 will be announced by the second pair. For this you can use the given command
neighbor x.x.x.x advertise-map toadvertise non-exist-map ifnotexist
access-list 10 permit 172.28.23.0 0.0.0.255
access-list 20 deny 10.1.3.0 0.0.0.255
access-list 20 permit any
access-list 30 permit 10.1.3.0 0.0.0.255
route-map ifnotexist permit 10
match ip address 30
route-map ifnotexist deny 20
route-map toadvertise permit 10
match ip address 10
regards
shivlu
kmmehlkmmehl Wed, 06/18/2008 - 00:35
so i can advertise my /24er routes upstream so only the nets i want will terminate on sitea and siteb?
shivlu jain Wed, 06/18/2008 - 00:44
you can advertise the /24 by one end and with the conf given the seocnd link will chk will the first goes down then it willl be advertise bty the other end.
regards
shivlu
kmmehlkmmehl Wed, 06/18/2008 - 04:49
Well i dont want a fallback.. it should be only static.
